Robust Comfort Tool Rests
- Hardened steel bar on the top edge will not dent or nick
- Robust; solid steel construction
- Comfortable when using overhand or underhand grip
- Get close to the work for maximum tool support
- Profile allows lowering of tool handle and greater control of cuts
Explore the Robust Tool Rest range
Robust by name and robust by nature, these tool rests offer superb stability with a hard wearing, solid steel bar that provides a smooth turning experience.
Key features
Made from solid steel for strength, stability and smooth support.
A range of diameters, heights and lengths to suit a variety of lathes.
Stay close to your work with a tight radius - more control, less chance of knicks.
A comfortable fit whether you use a overhand or underhand grip.
Which rest do I need?
With a wide range of tool rests to suit a host of turning projects, explore our Robust Tools Rests and discover which is the right fit for you and your lathe.
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
Robust Comfort Tool Rests; an apt description if ever there was one. Each tool rest features a round, hardened steel bar welded to the top edge. This bar will not dent or nick and tools will continue to glide smoothly even after years of turning. In addition, being solid steel, rather than cast iron these rests certainly deserve the name Robust.
The curvature, angle and height of the rest combine to form the Comfort part on the name. Your hand fits comfortably in the radius of the rest, whether you use an overhand or underhand grip. You can get the rest close to the action for maximum tool support whether below or above centre height. Finally, it allows you to lower the tool’s handle for shear scraping and skew cutting action.
The 1" stem tool rests are compatible with the following Axminster lathes, Craft AC355WL, Trade AT350WL and AT406WL. The 30mm stem tool rests are compatible with the Axminster Trade AT508WL lathe.
