Shaper Upcut Spiral Cutter 8mm Shank
- Ideal for intricate cuts and finer details
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
The spiral upcut design lifts waste out of the cut, at the same time helping keep the Shaper down on the work surface. These solid carbide cutters ensure a very clean fast action, greatly reducing tearout and help ensure a smooth finish. The design gives a shear cutting action with rapid waste removal. Available in either 3mm or 6mm diameter.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Shank Diameter | 8 mm |
