Shaper Engraving Cutter 8mm Shank
- Engrave a wide variety of materials
- 60° cutting angle for shallow v-cuts
- 8mm shank fits Shaper Origin’s standard collet
Shaper 3mm Upcut Spiral Cutter 8mm ShankSpecial Price £23.80 £19.83 was £28.00 £23.33 Save £4.20 £3.50
Shaper SYS1 Customisable Storage CaseSpecial Price £61.20 £51.00 was £72.00 £60.00 Save £10.80 £9.00
Shaper 6mm Upcut Spiral Cutter 8mm ShankSpecial Price £23.80 £19.83 was £28.00 £23.33 Save £4.20 £3.50
Shaper Essential Bit Set in Micro Systainer Set of 3Special Price £84.16 £70.13 was £99.00 £82.50 Save £14.84 £12.37
This solid carbide engraving router bit has a 60° cutting angle for shallow V-cuts. Perfect for engraving a variety of materials including any wood type, plastic, and selected non-ferrous metals. The 8mm shank diameter is compatible with the 8mm collet supplied with the Shaper Origin CNC router. Solid carbide composition keeps your edge sharp even after hours of use. Overall Length: 54.5mm, shank: 8mm.
EAN Barcode | 859790007191 |
K = Cutter Angle | 60° |
Shank Diameter | 8 mm |
X = Depth of Cut | 7 mm |
International delivery is unavailable for this product.
