Shaper Origin Router, Workstation & Pro Care
- Our specialist consultants will be happy to discuss Shaper products with you and offer expert guidance, as well as provide onsite visits and product demos of the Shaper range. Please call 03332 406406 or email sales@axminstertools.com.
- Featuring a large screen
- Shaper Workstation for vertical and horizontal workholding
- Includes Shaper Pro Care enhanced support
- Portable, precision CNC routing anywhere any time
- Engineered by Shaper; assembled by Festool
- Limitless possibilities packed into a Systainer case
- On-tool CAD or import designs via USB or wirelessly
- Make perfect mortice and tenon joinery, box joints and more
- Secure small and difficult to fixture workpieces
Shaper Origin
This Shaper Origin handheld precision CNC router offers unparalleled accuracy, flexibility and efficiency. Shaper Origin features a larger 5.5” high resolution screen, a 25% increase in size. The entire assembly is now housed in a sleek, super strong aluminium unibody construction. The Shaper Origin, literally puts CNC routing at your fingertips.
Designed and engineered by Shaper and assembled by Festool in Germany, this machine puts all the benefits and advantages of CNC routing into any workshop. Packed into a Systainer3 case the Shaper Origin neither takes up large amounts of floor space nor is the size of the workpiece restricted. Being handheld, the Origin can be used in virtually any workshop and anywhere else. Take CNC routing to the job, work onsite on any size of project; on floors, in kitchens, onboard boats, literally anyplace.
The Shaper Origin saves time spent in producing templates as the template is stored in the machine’s memory, allowing you to get straight on with the job. This machine offers limitless possibilities. Create complex joinery, intricate inlays, fine engraving, decorative parquet flooring, lettering and sign writing
Like any CNC machine, pre-programmed computer software dictates the movement of tool. Origin features precision X, Y and Z axes with automatic tool tip detection. The large screen displays the path of the design for you to follow, the really clever bit is the full auto correction for the movement of your hands guaranteeing precise results every time.
The on-tool CAD (Computer Aided Design) features means you can draw basic shapes right into the Origin. There’s also the option to import more advanced and technical drawings to the machine via a USB stick, or wirelessly.
The Shaper Origin is supplied with Jenner Software and comes packed in a T-Loc Systainer with: 3mm Up-Spiral router bit, 6mm Up-Spiral router bit, 60° V engraving router bit, 2 x rolls of shaper tape and wrenches.
Two Year warranty on registration.
NB. This tool is only available for delivery to mainland UK
Shaper Workstation
The Workstation is the ultimate benchtop accessory for the Shaper Origin handheld CNC router. The Workstation is designed to streamline your workflow and expand the Shaper Origin’s abilities by offering rapid, repeatable and precise clamping of a wide range of workpiece configurations. The Workstation features a reusable ShaperTape field, an easily adjustable shelf for small or difficult to clamp workpieces, indexing pins for easy alignment and registration, and an angle fence for aligning stock quickly at exact angles. These features greatly reduce setup time and make it easier than ever to start cutting quickly.
The clamping face features 4 x T-track grooves, which will accept any clamp compatible with 8mm T-track.
Workstation includes two T-Track clamps.
Overall W 515mm x D 465mm x H 250mm, weight: 9.75kg.
Shaper Pro Care
The Shaper Pro Care enhanced warranty support package; includes:
A focus on “Zero Downtime”, fast tool replacement should Shaper Tools be unable to fix the tool.
A dedicated live support phone line direct to Shaper Tools and email support.
