Shaper Upcut Spiral Cutter 8mm Shank
AX1043580
AX1043580
- Ideal for intricate cuts and finer details
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
Shaper SYS1 Customisable Storage CaseSpecial Price £61.20 £51.00 was £72.00 £60.00 Save £10.80 £9.00
Shaper Essential Bit Set in Micro Systainer Set of 3Special Price £84.16 £70.13 was £99.00 £82.50 Save £14.84 £12.37
Axminster Workshop Centrotec Compatible Depth Adjustable Bit HolderSpecial Price £3.98 £3.32 was £6.98 £5.82 Save £3.00 £2.50
Show more
Show less
The spiral upcut design lifts waste out of the cut, at the same time helping keep the Shaper down on the work surface. These solid carbide cutters ensure a very clean fast action, greatly reducing tearout and help ensure a smooth finish. The design gives a shear cutting action with rapid waste removal. Available in either 3mm or 6mm diameter.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Shank Diameter | 8 mm |
#AxminsterTools
