Starrett Fastcut Bi-Metal Holesaws
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £18.28 £15.23
The Starrett Fast Cut Bi-Metal Holesaws provide a smoother, faster cut on a wide range of materials, when compared to the previous constant pitch saw. Improved tooth material and 5.5 TPI/25mm tooth form for enhanced heat and wear resistance and greater product life. Specifically suited to cutting stainless and mild steel sheet, they will also cut through tubes with a wall thickness of up to 3mm (1/8in). Specification: Cutting Depth: 41mm.
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
