UJK Pocket Hole Plug Cutter
- Create your own pocket hole plugs
- Use in a pillar drill or drill stand
- Cuts 9.5mm (3/8") diameter, plugs 55mm long
- Maximum speed 700 RPM
UJK Replacement 22mm Bit for Pocket Hole Drill (Pair)From £7.38 £6.15 -
UJK Replacement 12mm Bit for Pocket Hole Drill (Pair)From £6.68 £5.57
Make your own pocket hole plugs. Simply use the plug cutter in a pillar drill to create you own plugs using matching or contrasting timber, glue them in, trim using a flush cut saw and sand to a finish. Cuts 9.5mm (3/8") diameter, plugs 55mm long. Maximum speed 700 RPM.
| EAN Barcode | 5052511062768 |
