Universal Corners for Strap Clamps (Pkt 4)
202404
From £13.88 £11.57
  5. Half Star
7 Reviews
In Stock - Ready to dispatch
  • Variable angle corners will clamp joints from 30° to almost 180°
  • Pivoting pads interlock so that the tip of the joint will always be properly aligned
  • Integral tabs clip on to the webbing, corners stay in place when tightening or repositioning
Strap clamps are great for clamping up odd shaped frames; however, getting the corners aligned properly can be a challenge. Most strap clamps are supplied with corners intended for clamping 90° joints. These variable angle corners will clamp joints from 30° to almost 180°. The pivoting pads interlock so that the tip of the joint will always be properly aligned. Integral tabs clip onto 25 mm webbing so the corners stay in place when tightening or repositioning. Made from strong glassfibre reinforced nylon, these corners will easily withstand the forces applied and provide protection to the workpiece and the web. Sold in packages of four.
4.40 7
