Yorkshire Grit is an abrasive paste used by woodturners across the world. Available in both Microfine (for resins/hybrids/wood) and Original (for wood), it’s known for its effectiveness in enhancing the surface of wood and achieving a smooth, polished finish.
Yorkshire Grit Microfine is an advanced abrasive paste designed for woodturners to achieve an exceptionally smooth and fine surface finish on wooden surfaces. The abrasive paste gives a fine keyed surface to your woodturning projects before adding a final finish. The products contain an ultra-fine, hand-blended mix of mineral oil, beeswax and abrasive powders that are carefully processed together without the use of solvents or other strong smelling and potentially harmful chemicals. The result is a creamy paste that acts like “liquid sandpaper” which reduces scratches left behind by lower grit dry sanding, and eliminating fine dust produced by higher grit sanding.
