Smooth, simple and reliable for any home workshop
Get precision and ease with this versatile planer thicknesser. With smooth operation and user-friendly features, it’s a great choice for any DIY or home workshop.
A yellow and silver planer thicknesser with a white fence, shown in a workshop setting with wood panels leaning against a white wall.
Strong and smooth tables
Smooth aluminium planer tables & cast iron thicknesser tables help timber glide easily through the machine, and they’re also rust-resistant.
Steel infeed on a planer thicknesser
Steel infeed rollers
The steel infeed rollers grip the timber and ensures a long life. It also reduces the amount of maintenance required.
Blades on a planer thicknesser
Double the blade life
Razor-sharp, quick-change double-edge planer blades deliver excellent performance. When blunt, they are easy to change by a simple rotation.
A split image of the same planer thicknesser showing it both planing and thicknessing
Easy change from planer to thicknesser
Switching from planing to thicknessing is efficient and easy.
Planing a piece of wood
Rigid adjustable fence
The adjustable fence tilts from 90 to 45 degrees for chamfered and angled cuts.
induction motor on a planer thicknesser
Induction motor
The 2200W quiet induction motor is maintenance free, powerful and robust for smooth operation
A planer thicknesser on wheels, with a yellow and black body and a white top panel, shown in a workshop setting with a person standing beside it.
Wheel kit included
The wheel kit ensures that the machine is portable and quick to put away.
Guard on a planer thicknesser
Safety
The planer thicknesser is fully guarded with integral safety switches helping to prevent cutting without the guards being in place. It also features anti-kickback fingers that help prevent the timber from kicking back when it first contacts the rollers.
Perform Planer Thicknesser connected to a Perform dust extractor in a workshop setting. A person ain a checked shirt and jeans feeds a piece of timber through the planer thicknesser
Remember your extraction
The Perform PD57E 1HP Dust Extractor is a reliable partner for your Planer Thicknesser, helping you maintain a cleaner and healthier workspace. It efficiently collects dust and debris, making it easier to focus on your craft and enjoy your time in the workshop.
Shop now
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
The Perform PD10PT 260mm Planer Thicknesser is designed to deliver consistent results for the home workshop and is for beginner use. If you're looking to create straight edges or require flat, square timber boards for activities such as routing, pyrography and more, a planer thicknesser converts rough boards into user-friendly materials. Use on natural wood, hard and soft woods or MDF, Plywood etc.
It features smooth aluminum planer tables and cast iron thicknesser tables, ensuring smooth operation and resistance to rust, making it a reliable addition to your workspace. The steel infeed rollers grip the timber firmly for a long service life and reduces maintenance required. The HSS double edge planer knives offer excellent durability and when they dull, you can simply rotate them for a fresh edge. An easily adjustable fence, with stops at 90 and 45, lets you achieve chamfered and angled cuts with ease. Powered by a single 2.2kW induction motor, the PD10PT runs quietly and smoothly, perfect for any woodworking project.
The Perform PD10PT offers 13,000 cuts per minute, thanks to its HSS disposable cutter type. It has a 63mm cutterblock diameter that spins at 6,500rpm, along with a 100mm dust extraction outlet for safety and cleanliness. Feed speed is set at 5 meters per minute, and the machine uses two knives to produce a smooth finish.
Switching between planer and thicknesser functions is quick and efficient when working on different tasks. Table adjustments are straightforward, allowing for efficient setup and precise results.
The planing table is 1,040mm long, supporting a maximum depth of cut of 3mm for both planing and thicknessing. It can handle a maximum planing and thicknessing width of 260mm and a maximum thicknessing height of 160mm. The machine requires a minimum extraction airflow of 1000m³/hr to maintain performance.
It is fully guarded with integral safety switches to prevent cutting without the guards being in place. It also features anti-kickback fingers that help prevent the timber from kicking back when it first contacts the rollers. A wheel kit is included for easy maneuverability around the workshop and quick storage when not in use.
The Perform PD10PT Planer Thicknesser is an ideal choice for those seeking a reliable, user-friendly, beginner planer thicknesser with features that support quality results.
Its overall dimensions are 1,150 x 960 x 980mm (L x W x H).
Please note, if you require an EU plug, please ensure you purchase 113595.
Dust Extraction Outlet 100 mm
Feed Speed 5 m/min
Knives HSS (Disposable) x 2
Overall L x W x H 1,150 x 960 x 980 mm
Power 2.2 kW
Rating Occasional Use
Min Extraction Airflow Required 795 m/hr
Plug Fitted UK 3 pin plug
Model PD10PT
Cuts per Minute 13,000
Cutterblock Diameter 63 mm
Cutterblock Speed 6,500 rpm
Length of Table 1,040 mm
Max Depth of Cut Planer 3.0 mm
Max Depth of Cut Thicknesser 3.0 mm
Max Planing Width 260 mm
Max Thicknessing Height 160 mm
Nett Weight 71 kg
Number of Knives 2
Number of Motors 1
Voltage 230 V
Warranty Perform 1 Year Warranty
EAN Barcode 5052511142163
