Perform PD150BDS Belt & Disc Sander 230V
113366
From £124.98 £104.15
2 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Sep
  • Compact, 100mm belt and 150mm disc sander
  • Tilting table with mitre fence for sanding compound angles
  • Close fitting guarding helps to achieve high levels of extraction
  • Ideal for detailing, shaping and finish sanding
A versatile addition to any small home workshop
This Perform Belt & Disc Sander enables shaping, sanding and profiling to be carried out easily and safely on wood.
Perform PD150BDS Belt & Disc Sander - compact design
Compact design
Easy to store when not in use, the compact design makes the sander ideal for those with smaller workspaces.
Perform PD150BDS Belt & Disc Sander - strong, robust construction
Strong, robust construction
A heavily constructed chassis is constructed in a single iron casting; this supports the belt arm and tables. There are also locating holes for securing the sander to a workbench, if desired.
Perform PD150BDS Belt & Disc Sander - compounds and mitres
Compounds and mitres
The table features a mitre slot for bevel and compound angle sanding. Both sanding functions use a decent size worktable which tilts to 45°.
Perform PD150BDS Belt & Disc Sander - multi belt position
Multi belt position
The belt sanding plate can be positioned vertically or horizontally.
Perform PD150BDS Belt & Disc Sander - hook and loop
Hook and loop
Hook and loop velcro discs are used to make disc changes easy and quick. It also saves adhesive residue being left on the machine.
Perform PD150BDS Belt & Disc Sander - safeguard your health
Safeguard your health
The belt is fitted with close fitting guarding to help with efficient dust extraction for safeguarding health. Simply connect your belt and disc sander to a suitable vacuum extractor via the 63mm dust port to achieve almost 100% extraction.
Abrasives
The right grit makes all the difference
From rough shaping to a fine finish, having the right abrasive for each stage makes your projects look their best. Explore our selection and find the perfect grits for your work.
The Perform PD150BDS Belt & Disc Sander is a compact and neatly designed, light use sander. It features a 100mm x 915mm belt and a 150mm disc. The belt sanding platen can be used vertically or horizontally. The worktable can be used for either function, and tilts up to 45°. The mitre fence allows easy bevel and compound angle sanding.
The machine has close fitting guarding and a 63mm dust extraction outlet. When connected to a suitable vacuum extractor, it offers almost total dust extraction. The main body of the machine is a single cast iron therefore is strong and stable. It has locating holes for securing the sander to a workbench.
The PD150BDS makes an ideal beginner sander or for those simply using it for light use for shaping, sanding and profiling. There is a selection of hook and loop abrasive belts and discs available for various applications.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Warranty Perform 1 Year Warranty
Perform 1 Year Guarantee
With every Perform machine, you get our 1-year guarantee, which includes:
Complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for light, occasional use. They must be maintained and serviced in line with our schedule and are not intended for continuous or high operation, otherwise guarantee may be void.
Find out more
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBirthday CakeA birthday cake with a candleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesChristmasChristmasClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPound SignA pound currency sign in a circlePreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSign InSign In to your accountSign OutSign Out of your accountSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5 2
