These Axminster Abrasive Wraps are precision cut (79 × 3,590mm) for the Axminster Professional AP640DS Drum Sander, delivering efficient stock removal, consistent performance, and long service life. Made from aluminium oxide with a heat-resistant bond to reduce clogging, they feature a heavy-duty cloth backing for strength and durability, ensuring easy installation and a clean, even finish with minimal scratch pattern.
Suitable for softwoods, hardwoods, veneers, and panels, they are ideal for thickness sanding, panel and board flattening, surface preparation, and graduated sanding through multiple grit stages. Available in 80, 100, 120, 180 and 240 grit, they support everything from aggressive material removal (80g) to general sanding (100 and 120g) and fine finishing (180 and 240g). When used on the AP640DS Drum Sander, two wraps can be loaded simultaneously, coarse on the front drum and fine on the rear, saving time while achieving a smooth, uniform finish in a single pass.
Abrasive Grit 100
Web Attribute Set Drum Sander Machine Loadings
EAN Barcode 5052511146819
Accessories
  • Axminster Professional AP640DS Drum Sander 230V Axminster Professional AP640DS Drum Sander 230V
  • Axminster Abrasive Belt & Disc Cleaners Axminster Abrasive Belt & Disc Cleaners
    $21.00 USD - $41.00 USD
  • Axminster Professional AP25AFS Air Filter - 230V Axminster Professional AP25AFS Air Filter - 230V
  • JSP Powercap Powered Respirator with Impact Visor JSP Powercap Powered Respirator with Impact Visor
  • Cascamite Powdered Resin Wood Glue Cascamite Powdered Resin Wood Glue
    $11.00 USD - $61.00 USD
  • Cascamite Cascarez D3 Fast Grab Wood Glue Cascamite Cascarez D3 Fast Grab Wood Glue
  • Chestnut Finishing Oil Chestnut Finishing Oil
    $18.00 USD - $33.00 USD
  • Chestnut Jenny Brushes Chestnut Jenny Brushes
    $5.99 USD - $6.99 USD
