These barrel cutters will cut plugs and short dowels up to 50mm in length, when matched with a corresponding drill they can be used to cover screw holes or make a small repair in damaged timber, they also make a good decorative plug. Designed for use in a drill press they give a very clean cut.
Plug Diameter 30 mm
Web Attribute Set Plug Cutters & Plugs
EAN Barcode 5052511045518
