Manufactured from close grained cast iron these angle plates are precision ground on the faces and ends to give accurate results when marking out or machining. These angles plates are precision ground, flat and square having and accuracy in paralellism and squareness within
Axminster Engineer Series Ground Angle Plates 100 x 100 x 100mm
| Dimensions | 100 x 100 x 100 mm Web Attribute Set: Vee, Gauge Blocks & Angle Plates |
| EAN Barcode | 5052511040971 |
