In every workshop, space is at a premium. The ability to move a piece of equipment into a convenient working position or park it out of the way is a huge bonus.
Our heavy duty mobile base has two fixed wheels at the rear and features two castoring wheels at the front. It is a practical method for manoeuvring heavy machines into position safely and with ease. Once the machine is in position, screw-down feet raise the castoring front wheels off the floor, allowing the base to rest securely on the floor. The Axminster Heavy Duty Mobile Base takes the strain out of moving machinery around your workshop.
Easily adjustable to suit your machine's base, the maximum rectangle is 720 x 850mm, the minimum is 480mm x 660mm or 530mm x 610mm with a maximum weight limit of 400kg.
Additional Accessories No
Web Attribute Set General Machine Accessories
EAN Barcode 5052511102075
