The Axminster Mobile Machine Stand provides solid support for benchtop machines or equipment that requires a dedicated stand. The generous size top is 605 x 530mm, meaning two machines can be fitted if required. Its adjustable height range of 630–810mm makes it customisable for your workspace.
Universal mounting slots make installation simple, allowing machines to be secured without the need to drill additional holes. The integrated storage shelf provides convenient access to tools and accessories, while swivel castors with a foot-operated pedal make it easy to move the stand or lock it securely in place. Strong and stable in use, it helps ensure accurate cuts and smooth, reliable operation throughout the workshop.
Please note that there is a weight limit of 200kg.
Overall L x W x H 608 x 531 x 810mm
Web Attribute Set General Machine Accessories
EAN Barcode 5052511143009
