Axminster No. 7 Bedrock Jointer Plane is designed for accurately jointing board edges, flattening large surfaces and preparing work for final smoothing. Its long sole bridges bumps and hollows, helping produce straight, true edges for seamless glue joints while also making it highly effective for final flattening before a smoothing plane is used.
The Bedrock-style design provides maximum support for the cutting iron, helping to reduce blade chatter and improve surface finish. A fully adjustable frog allows the mouth opening to be fine-tuned without removing the blade assembly, while the traditional disc-style lateral adjustment lever and stainless steel Norris-style adjuster provide precise control over blade alignment and depth of cut. Well-shaped hardwood handles ensure comfortable use, even during extended planing sessions.
The ductile iron body is precision machined with a flat, ground sole measuring 560mm long. Fitted with a 60mm (2⅜) wide cryogenically treated high carbon steel blade, the plane offers excellent edge retention and durability. The blade is supplied with a 25° bevel and requires only final honing before use. Weighing 4.2kg, the No. 7 has the mass needed for stable, consistent performance across wide boards and long edges.
Axminster woodworking tools are designed to deliver reliable performance, traditional craftsmanship and excellent value. Combining proven designs with quality materials, they provide dependable tools for serious woodworking.
Ideal for furniture makers, cabinetmakers, joiners and hand tool enthusiasts, the Axminster No. 7 Bedrock Jointer Plane excels at edge jointing, panel flattening and final surface preparation. Requiring only minimal setup before use, it is an essential plane for producing straight, accurate work.
Sole Length 560 mm
Web Attribute Set Hand Planes
EAN Barcode 5052511147212
