The Axminster Professional AP250FSG Flexi Shaft Grinder is a compact, high-performance woodworking grinder designed for precision work across a wide range of materials. Whether you're engraving, cutting, drilling, grinding, carving or polishing, this versatile grinder handles wood, glass, leather, stone, and more with ease. Its robust construction ensures long-lasting durability, and its lightweight, portable design makes it easy to transport and store - perfect for those working across multiple locations or with limited bench space.
Engineered for precision and control, it features a high-torque, low-noise DC24V brushless motor that maintains consistent performance even at low speeds. The built-in variable speed adjustment and RPM tachometer allow you to fine-tune your settings and record them for future use, while the forward/reverse switch enhances flexibility during operation. A foot pedal provides instant start/stop control, giving you hands-free operation and greater precision - especially useful for intricate or repetitive work.
To get the most from your AP250FSG, don’t forget to select the right handpiece for your needs (sold separately). Choose from three styles: the HC110 Chuck Style, HC120 Chisel Style, or HC130 Collet Style. A wide range of compatible accessories is also available, including rasps, chisels, and cutters - everything you need to customise your setup for any application. With its enhanced performance and user-friendly features, this variable speed grinder is a valuable addition to any workshop.
Rating Frequent Use
Corded or Cordless Corded
Cable Length 1.5 m
Motor Power 250 W
Plug Fitted 230V - UK BS89/13 13A Type G (2P+Earth)
Web Attribute Set 230V Rotary Multitools
EAN Barcode 5052511138876
