Delta triangular backing pad (93mm corner to corner) with extraction holes. The backing pad allows you to get into the tightest of corners. Use with abrasive system with hook and loop backing.
The Starlock fitting is suitable for Bosch and Fein Multi-Tools as well as other makes using the Oscillating Interface System (OIS™). The Starlock fitting ensures a secure fit with maximum power transfer.
