Bosch EXPERT Self Cut Speed Spade Drill Bit Set is designed for exceptionally fast drilling in wood, making it ideal for electricians, installers and construction professionals. Featuring Bosch Tip Technology and a self-feeding threaded tip, the bits pull themselves into the material with minimal effort, helping you drill faster with less pressure.
The advanced wave-shaped spade design removes chips efficiently, reducing resistance and increasing drilling speed. Suitable for use with rotary drills/drivers and impact drill/drivers, these bits deliver up to three times faster performance than standard Bosch spade bits.
Part of the Bosch EXPERT range, these spade bits are designed for professional users who need fast, clean and efficient hole drilling in timber and sheet materials.
Web Attribute Set Hex Drive Bits
EAN Barcode 6949509245335
