Chroma Craft Rustina is a unique water-based system, which you can use to produce the look of ancient corroded metal on a variety of surfaces, including wood, metal, ceramic, glass and plastics.
Developed with Woodturner Nick Agar, this system imparts a realistic aged blue/green verdigris or a red/brown rust effect on turned objects and other items. It is a simple four stage process that only involves wielding a paintbrush.
The first stage is the Primer, which provides the base colour for your chosen effect; available in Black, Grey or Road Rash. The Primer is applied to give a background for the metallic paints. The black and grey go well under any of the metallic paints. Road Rash is a little different in that it contains small coarse particles that give you the textured finish of heavily rusted iron.
