The DeWALT FLEXTORQ Bit Set contains a versatile selection of impact-rated screwdriver bits for a wide range of fastening tasks. With Phillips, Pozidriv, Slotted, TORX and PR2 drywall bits, the 32-piece set is ideal for use with impact drivers.
The high-quality impact-grade bits are designed to withstand demanding applications, while the magnetic bit holder keeps bits firmly in place during use. With multiple sizes and commonly used bits included, the set is neatly stored in a reusable pocket case for easy organisation and transport.
DeWALT is trusted by professionals for tough, reliable power tools and accessories designed to perform in demanding trade and workshop environments.
Supplied with;
10 x 25mm Pozidriv Bits: PZ1 (x2), PZ2 (x5), PZ3 (x3)
5 x 25mm Phillips Bits: PH1, PH2 (x3), PH3
2 x 25mm PR2 Drywall Bits
3 x 25mm Slotted Bits: 6mm (x2), 8mm
11 x 25mm TORX Bits: TX10 (x2), TX15 (x2), TX20 (x2), TX25 (x2), TX27, TX30, TX40
1 x Magnetic Impact-Ready Bit Holder
1 x Reusable Pocket Case
Web Attribute Set Screwdriver Bits
EAN Barcode 5054905323592
