The Festool TSV 60 K plunge-cut saw offers splinter-free cuts like you have never seen. With a built-in scoring blade preceding the main blade you are guaranteed perfect results every time. Look forward to the cleanest of finishes, on both sides of the material, from the very first cut. No additional cleaning or work required.
The TSV 60 K offers fast and efficient cuts in timber, wood based and composite materials. Perfect scoring cuts even on mitre cuts from up to 45.
The 47mm diameter diamond tipped scoring saw blade is long lasting and gives a perfect quality cut, even in HPL materials or melamine coatings. The scoring function can be switched on or off as required.
This innovative circular saw features ai KickbackStop minimising the risk of injury and damage to the workpiece. The saw detects a kickback in the blink of an eye and stops the motor within a fraction of a second. Once the saw has been triggered, it is ready for use again straight away.
The brushless EC-TEC motor makes the TSV 60 K virtually maintenance-free and extremely powerful.
With the TSV 60 K, workshop-quality results can be replicated on site every bit as good as with a stationary machine. The FastFix spindle stop on the main saw blade makes changing the saw blade quick and simple. The TSV 60 K is fully compatible with Festool guide rails, offering 60mm cutting depth when fitted to the FSK cross cutting guide rail or FS guide rail.
Supplied with: 42 tooth TCT saw blade, 47mm diamond scoring saw blade, and Systainer SYS3 M 437.
Bevel Angle Range 0 - 45
Dust Extraction 27 mm / 36 mm Outlet
Max Depth of Cut @ 45º 45 mm
Max Depth of Cut @ 90º 62 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 168 mm
Sound Power Level LwA [Uncertainty K] 101 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 90 dB(A) [3.0 dB]
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Saw Blade Speed 3,000 - 6,800 rpm
Manufacturer Part Number 576733
Web Attribute Set Plunge Saws
EAN Barcode 4014549373774
