The Festool PSBC 500 EB Jigsaw is a powerful, versatile woodworking tool designed for precise straight, curved and angled cuts. With a cutting depth of up to 120mm in wood, it is capable of handling everything from large timber sections to intricate curves and detailed cut-outs. It is ideal for producing circles and curves with ease, as well as slanted cuts, and can handle even solid wood. It’s an ideal tool for furniture and kitchen joinery, as well as being useful when working with stair treads, beams and rafters.
The PSBC 500’s three-way saw blade guidance system provides excellent cutting accuracy, even at an angle. This is further enhanced with the adjustable saw table which can be swivelled to up to 45⁰ either way. The adjustable speed control and four-stage pendulum action allow the tool’s performance to be tailored to different materials and applications. The jigsaw also features speedy, tool-free FastFix blade replacement for minimal downtime and uninterrupted work. With an integrated dust extraction connection, blowing function and switchable lighting, you will always have a clear view of your cut line. The splinter guard ensures a tear-out free cut and clean edges.
Compatible with Festool 18V batteries and chargers and fully integrated into the Festool cordless system for maximum flexibility across multiple tools.
Supplied as a body only machine, battery and charger available separately. Supplied with two jigsaw blades (wood fine and wood universal), splinter guard, hose connector and Systainer³ SYS3 M 187.
Battery Voltage 18 V
Rating Trade/Professional
Stroke Length 26 mm
Sound Power Level LwA [Uncertainty K] 99.00 dB(A)
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 91.00 dB(A)
Vibration Cutting Wood [Uncertainty K] 7.00 m/s²
Max Cutting Depth 120 mm
Manufacturer Part Number 576972
Centre 26.00 mm
Cutting Depth in Wood 120 mm
Cutting Depth in NF Metals 20.00 mm
Cutting Depth in Steel (Soft) 10.00 mm
Max. Inclined Position (Both Sides) 45.00 °
Pendulum Cover Adjustment in Stages 4.00
Stroke Rate 1,000 - 3,800 min⁻¹
Web Attribute Set Cordless Jigsaws
EAN Barcode 4014549389614
Accessories
  • Festool Tabless Battery 4.0Ah 18V Festool Tabless Battery 4.0Ah 18V
    Out of Stock
    £117.82
  • Festool Energy Battery Set SYS18V TBX 4.0Ah & DUO Charger 18V Kit Festool Energy Battery Set SYS18V TBX 4.0Ah & DUO Charger 18V Kit
  • Festool TCL 6 Rapid Battery Charger Li-Ion 10.8V-18V
  • Festool PSBC 500 Circular Core Marker Set Festool PSBC 500 Circular Core Marker Set
