The table runs along a robust aluminium profile on four bearing rollers giving ultra-smooth travel. Attached to the left hand side of the TKS 80 saw table, it enables cross cutting up to 920mm in width. The profile can be attached in a choice of two positions depending on the type and size of the workpiece. Adjustable stops front and rear can be used to limit the length of travel. Installing the sliding table is straightforward. Installation and all set-up adjustments can be done in just a few minutes.
Festool
Festool TKS 80 Sliding Table ST TKS80
| Manufacturer Part Number | 575827 |
| Web Attribute Set | Saw Bench Accessories |
| EAN Barcode | 4014549343593 |
