Fisch
FISCH 25 Piece HSS Brad Point Drill Bit Set
SKU: 102530
£79.98
£66.65 Excl. VAT
  • Extremely resistant: high quality HSS hardened to 62 HRC
  • Ground centre point and spurs for precise positioning and clean cut
  • Smooth chip ejection, smooth, ground spiral
  • Suitable for drilling in soft and hard wood, glue-laminated boards, MDF etc
  • Use for drilling plastic and acrylic glass
  • Robust high quality case gives easy access to individual drills
  • 19 piece set covers a diameter range from 1 to 10mm in 0.5mm steps
  • 25 piece set covers a diameter range from 1 to 13mm in 0.5mm steps
  • Sizes 1mm to 2.5mm are standard twist drills, with sizes 3mm and upwards being brad point drills
The 25-piece HSS drill from FISCH is suitable for drilling into hard and soft wood, MDF and other manufactured boards. They have a precision ground point with twin cutting spurs for precise positioning and a clean cut. Made of very resistant high speed steel to EN ISO 4957 with a hardness of approximately 62 HRC, these drills give you very good and precise results. Their cylindrical shanks allow their use in all common battery operated and hand-held drilling machines as well as in vertical and bench drilling machines. The drill set covers a diameter range from 1 to 13mm in 0.5mm steps. Sizes 1mm to 2.5mm are standard twist drills, with 3mm to 13mm being brad point drills.
Web Attribute Set Wood Boring Bits
EAN Barcode 9002696360391
