The Fiskars PowerArc™ Heavy‑Duty Utility Snips are designed to deliver exceptional cutting performance on demanding materials where ordinary snips struggle. Their high‑grade stainless steel blades slice cleanly through thick, rigid and slippery surfaces without separating, ensuring every cut stays controlled and consistent. These snips are ideal for workshop, DIY, craft and household tasks where strength, stability and precision are essential.
Engineered with PowerArc™ blade technology, these snips increase leverage throughout the cut, meaning less effort is required even when tackling dense materials. A serrated blade edge securely grips surfaces so they won’t slip as you cut, while the Offset Easy Action™ handle keeps your hand safely away from the work. The spring‑assisted, ergonomic design reduces fatigue during extended use, and SoftGrip® touchpoints offer comfort and secure handling. An easy‑open lock protects the blades during transport and storage.
With over 375 years of design heritage, Fiskars is recognised globally for creating tools that combine performance with exceptional ergonomics. Their cutting tools are crafted for durability, comfort and precision, making them a trusted choice for professionals, makers and home users who value reliability and long‑lasting quality.
The PowerArc™ Heavy‑Duty Utility Snips are suitable for cutting thick card, plastic packaging, rubber, rope, carpet, flooring materials, leather, canvas, heavy fabrics, wire mesh, metal strapping and other dense, resistant materials.
Web Attribute Set Snips
EAN Barcode 6411501701244
