White medium PUR shaped sanding block utilise 70 x 125mm quick change hook and loop backed abrasives. Extremely comfortable to hold and are excellent for sanding both flat or gently contoured surfaces. Very convenient for hand sanding as you can quickly swap abrasives as you work through the grit types.
Flexipads World Class
Flexipads Shaped PUR Sanding Block 70 x 125mm
| Overall L x W x H | 125 mm x 70 mm x 30 mm |
| Web Attribute Set | Hand Sanding Blocks |
| EAN Barcode | 5021526930706 |
