This multi-volt 1/2 cordless router from Hikoki is a quality, high powered router, an excellent choice for busy workshops and tradespeople.
Its compact, lightweight design aids in its portability and use. It has a brushless motor for incredible power output, capable of handling heavy workloads and with fast cutting speeds. The speed control dial adds extra control to your work coupled and the dual LED lights provide for excellent visibility.
Fitted with a locking lever for precise depth adjustment and spindle lock for quick and easy bit change. Supplied with 1/4 collet to interchange between 1/2 and 1/4 router bits.
Designed for smooth groove cutting, window cutting, shaping and more, this router is a quality and versatile tool for your workshop.
Supplied with 1 x 1/2 collect, 1 x 1/4 collet, parallel guide, template guide, dust adaptor, 18V / 36V 5.0/2.5Ah Multi-Volt Li-ion Battery and charger and a carry case.
Battery Voltage 18 V 36 V
Collets Supplied 1/4 and 1/2
Overall L x W x H 148mm X 275mm X 280mm
Rating Home/Light Trade
Spindle Lock Standard Feature
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Cutter Speed 11,000 - 25,000 rpm
Manufacturer Part Number HIKM3612DAJP
Web Attribute Set Cordless Routers
EAN Barcode 4966376335954
