The Laguna A|Flux 12 Replacement Outer Filter is an essential component designed to maintain the high performance of your Laguna A|Flux 12 Air Filtration Unit. This outer filter captures larger 5 micron and above airborne particles, ensuring that the inner 1 micron filter can efficiently handle finer particles. By regularly replacing the outer filter, you can extend the lifespan of your air filtration unit and maintain a cleaner, healthier workspace.
Made from durable, washable materials, the Laguna A|Flux 12 Replacement Outer Filter is easy to clean and reuse, making it a cost-effective solution for maintaining optimal air quality. The filter's electrostatic properties enhance its ability to attract and capture dust, pollen, and other contaminants, providing superior air purification. Installing the replacement outer filter is a straightforward process, allowing you to quickly and easily maintain your air filtration system.
Web Attribute Set Filter Cartridges & Bags
EAN Barcode 5052511135578
