The Laguna A|Flux 12 Replacement Inner Filter is an essential component for maintaining the optimal performance of the Laguna A|Flux 12 Air Filtration Unit. This inner filter works with the outer filter to ensure that your air filtration system continues to operate at its best, providing you with clean and purified air in your workspace.
Crafted from high-quality polyester, the inner filter is capable of capturing particles as small as 1 micron, making it highly effective in removing dust, allergens, and other airborne contaminants. This not only helps in maintaining a healthier environment but also prolongs the life of your air filtration unit by preventing clogging and reducing wear and tear.
Replacing the inner filter is a straightforward process, designed to be user-friendly and hassle-free. The easy-to-replace feature ensures that you can quickly swap out the old filter with a new one, minimising downtime and keeping your workspace clean and safe. Additionally, the filter's durable construction means it will last longer, providing you with reliable performance over time.
Filter Performance 1 micron
Web Attribute Set Filter Cartridges & Bags
EAN Barcode 5052511135585
