The Laguna A/Flux 12 Air Filter is a state-of-the-art air filter designed for superior air cleaning and energy conservation. This unit is crucial for those demanding true air purification in their shop, removing wood particles that dust collectors miss.
With a 150W (1/5hp) motor, the A|FLUX 12 balances strong performance with low energy consumption. It recycles air in a 6m x 6m x 2.4m space up to 22 times per hour, ensuring a consistently clean environment. For optimal performance, it's recommended to cycle the air volume at least 10 times per hour.
The A|FLUX12 includes an electrostatic 5-micron pre-filter and a polyester 1-micron inner filter for cleaner air output. The electrostatic outer filter catches larger particles, while the inner filter captures particles down to 1 micron. The built-in air filter indicator alerts you when cleaning is needed, and both filters are easy to replace. The outer filter is washable, ensuring long-lasting performance.
Operate the unit effortlessly with the remote control, perfect for hard-to-reach installations. It has 4 eye bolts for ceiling suspension, 4 foam feet for bench mounting, and a remote-controlled hand unit with batteries. The built-in timer settings (30 minutes, 2 hours, 4 hours) allow for continued air cleaning even after work stops. Operating at a low sound level between 55.6dB and 59.6dB, it ensures a tranquil environment.
Experience superior air cleaning with the Laguna A/Flux 12 Air Filter, designed for quiet, high-level purification and smart energy conservation.
Comes complete with 4 eye bolts for ceiling suspension, 4 foam feet for bench mounting, remote control hand unit with batteries, 1.8m power cable with UK 3 pin plug.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Filter Performance Outer 5 micron Inner 1 micron
Overall L x W x H 712mm x 610mm x 305mm
Rating Home/Light Trade
Cable Length 1.8 m
Motor Power 150 W
Web Attribute Set Air Filters
EAN Barcode 5052511135400
