The Deluxe Wheel System is designed for maximum stability and ease of use. It features a single pedal mechanism that allows you to engage the wheels effortlessly. When you press the pedal, the wheels are lowered, lifting the equipment slightly off the ground, making it easy to move. Once you release the pedal, the wheels retract, and the equipment is set back down on its stable base, ensuring it remains secure and steady during use.
This system is compatible with several Laguna tools, including the Laguna 14|12 and 14|BX Bandsaws, and Laguna 12|16 Lathe. This compatibility ensures that you can easily integrate the wheel system with your existing Laguna equipment, enhancing the overall functionality and mobility of your workshop setup.
Web Attribute Set Bandsaw Accessories
EAN Barcode 5052511135479
