Enhance your Laguna Revo 12|16 Lathe with the Bed & Banjo Extension. This accessory extends the bed length, allowing you to work on longer pieces with ease and precision. It's perfect for larger projects like table legs and spindles, saving you time and effort by reducing the need to reposition your work. The additional banjo provides extra support and stability for your tool rest.
Constructed from high-quality materials, the Bed & Banjo Extension is durable and reliable, ensuring stability and reducing vibrations. Installation is straightforward, allowing you to integrate it into your lathe setup quickly. The high-torque motor controller ensures that wood-turners can handle workpieces up to 406 mm (16
The Expansion Set includes a 254mm (10
Upgrade your Laguna Revo 12|16 Lathe with the Bed & Banjo Extension for increased capacity, enhanced stability, and greater versatility in your woodworking projects.
