Enhance the mobility and versatility of your Laguna Revo 18|36 and 24|36 Lathes with the Laguna Wheel Kits. These kits are designed with 360° swivelling casters allowing you to easily manoeuvre the lathe into tight spaces. The dual gas struts ensure full mobility when engaged, yet 100% surface contact when released giving you the best of both worlds.
The Laguna Wheel Kits are equipped with heavy-duty casters that ensure smooth and effortless movement, allowing you to reposition your lathe with ease. This mobility is particularly beneficial in smaller workshops where space is at a premium, enabling you to maximise your workspace by easily moving the lathe out of the way when not in use. Additionally, the wheel kits feature locking mechanisms that secure the lathe in place during operation, ensuring stability and safety.
Constructed from high-quality materials, the Laguna Wheel Kits are built to withstand the demands of a busy workshop. The lathe sits on all four soft pads when in working mode, combined with the robust constructions means lathe remains stable and secure, even when being moved frequently. The four swivelling casters provide easy manoeuvrability, and the system requires no drilling, making installation straightforward.
Upgrade your Laguna 18|36 and 24|36 lathes with the Laguna Wheel Kits and experience the convenience of enhanced mobility and the assurance of stable, secure positioning for all your woodworking projects.
Web Attribute Set Woodturning Lathe Accessories
EAN Barcode 5052511135653
