Enhance your Laguna Revo 18|36 and 24|36 lathes with the Laguna 500mm Bed Extension, designed to elevate your woodworking experience. This accessory seamlessly extends the bed length of your lathe, providing you with the extra space needed to tackle larger projects with ease. Maximum outboard turning diameter with extension fitted is 812mm for 18|36 and 965mm for 24|36.
Imagine the freedom to work on longer pieces without the constant need to reposition your work. The 500mm Bed Extension offers just that, allowing for greater versatility and efficiency in your workshop. Whether you’re crafting intricate table legs or expansive bowls, this extension ensures you have the stability and support required for precision and accuracy.
The bed extension is supplied with a cast iron riser, which raises the tailstock as well as the tool rest extender and can be mounted in five positions, including perpendicular to the Headstock allowing better access. Crafted with the same high-quality materials and engineering excellence as your Laguna lathe, the Bed Extension is built to last. Its robust construction guarantees that it can handle the demands of your most ambitious projects, while its easy installation means you can quickly get back to what you love—creating beautiful, handcrafted pieces.
Upgrade your lathe today with the Laguna 500mm Bed Extension and unlock new possibilities in your woodworking journey.
Supplied with; 500mm bed extension, cast iron riser block and a tool rest extender.
Web Attribute Set Woodturning Lathe Bed Extensions
EAN Barcode 5052511135707
