The Cabineo starter set Includes 80 x Cabineo 8 M6 connectors, 40 x white cover caps, 40 x insert nuts, 1 x installation tool and 1 x Cabineo 1/4
Made to withstand vigorous use, the design possibilities are endless. Cabineo offers a discreet, fast and effective solution to join heavy-duty materials without compromise. The Cabineo 8 M6 allows you to make time and cost saving connections in a variety of materials. Connections can be made with aluminium, steel or HPL materials, as well as timber and man-made boards. The Cabineo 8 M6 boasts the same impressive credentials as the existing Cabineo family. The one-piece connector is quick and easy to install into a drilled or routed shape and requires no edge drilling and has a high clamping force.
Installing the Cabineo into the workpieces during the production process is possible, as there are no protruding parts, which could damage the finished surfaces. In addition,this eliminates the need for bags of separate loose fixings. Because the elements are already factory-installed, assembly is greatly simplified and considerably faster.
