These Lamello Cabineo X 12 Screws are designed for use with the Lamello Cabineo X connectors and create strong, reliable joints. With a high clamping force, they are suitable for making corner joints where the counterpart is a minimum of 13mm in thickness, or for making dividing panel joints where the counterpart material is a minimum of 24mm in thickness. Insert into the open housed Lamello Cabineo X connectors and screw into the material.
Suitable for a variety of materials including chipboard, MDF, plywood, soft and hard woods.
Includes 500 x Cabineo X 12 Screws, 1 x Cabineo X Screw in aid and 1 x Cabineo hexagon bit 1/4 GL 80mm.
Web Attribute Set Cabinet Hardware
EAN Barcode 7640149939798
