Mirka DEOS II 353CV is a powerful and compact orbital palm sander, slightly over 100mm tall and with an 81 x 133mm pad. It is mainly for woodwork and decorative painting, and is ideal for use on doors and windows, corners, edges and tight spaces. The sander features upgraded power compared to previous models; the body of the machines houses a 300W brushless motor for an extended service life, delivering plenty of power to finish sanding tasks quickly and efficiently.
The 353CV includes the same innovative features as the rest of the highly regard Mirka sander range. The body is very lightweight, making it easy to manoeuvre and handle. The grip is ergonomic, ensuring both comfort and complete control. There is variable speed control ranging from 5,000 - 10,000rpm, and the upgraded design makes it easy for the operator to change the speed. LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
Mirka DEOS II features an integrated vibration sensor with enhanced Bluetooth technology. The vibration sensor allows you to view and monitor vibration levels on a smartphone or tablet, via the myMirka app.
In combination with Mirka's Abranet abrasive and suitable vacuum extractor, the DEOS 353CV offers fast, efficient and dust-free sanding performance.
The Deco solutions kit includes:
230V DEOS 353CV palm sander
50 x Abranet strips grit P80
50 x Abranet strips grit P120
50 x Abranet strips grit P180
T-LOC storage case
Dust Extraction 27 mm Outlet
No Load Speed 5,000 - 10,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 80 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 69 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.6 m/s² [1.5 m/s²]
Motor Power 300 W
Plug Fitted UK 3 pin plug
Web Attribute Set Third Sheet Sanders
EAN Barcode 6416868519303
