The Deros II 350V is unique; with a compact body, 77mm disc and low weight (only 0.8kg), it is the perfect small sander. In the Deros II 350CV, you have a low profile, easily manoeuvrable sander, with efficient extraction and minimal vibration and sound levels. This 77mm sander with its user-friendly, compact body reaches small areas a regular sander cannot reach. The design makes it perfect for tackling small repairs, hard-to-reach areas, furniture restoration, painting prep, auto body dent, scratch repair and more. No more tired arms and wrists caused by holding a heavy awkward sander when sanding tricky areas.
This sander features upgraded power compared to previous models for even greater service life; the body of the machines houses a 300W brushless motor for an extended service life, with soft start and electronic pad brake for controlled sanding. The variable speed has a range covering 4,000 to 10,000rpm, while the 5mm oscillation offers high stock removal rates. The updated design makes it easy for the operator to adjust the sanding speed, as LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
It has the lowest vibration values in its class. You can monitor vibration levels in real-time with the myMirka app, which uses enhanced Bluetooth technology to track your vibration levels.
The Deco kit which comes with the DEROS II 350V includes:
50 x Abranet ACE discs grit P80
50 x Abranet ACE discs grit P120
50 x Abranet ACE discs grit P180.
2+1 Extended Warranty for Mirka sanders, registration required within 30 days.
Dust Extraction 27 mm Outlet
No Load Speed 4,000 - 10,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 78 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 67 dB(A) [3.0 dB]
Motor Power 300 W
Plug Fitted UK 3 pin plug
Web Attribute Set Random Orbit Sanders
EAN Barcode 6416868518955
