The Perform PD150BDS Belt & Disc Sander is a compact and neatly designed, light use sander. It features a 100mm x 915mm belt and a 150mm disc. The belt sanding platen can be used vertically or horizontally. The worktable can be used for either function, and tilts up to 45. The mitre fence allows easy bevel and compound angle sanding.
The machine has close fitting guarding and a 63mm dust extraction outlet. When connected to a suitable vacuum extractor, it offers almost total dust extraction. The main body of the machine is a single cast iron therefore is strong and stable. It has locating holes for securing the sander to a workbench.
The PD150BDS makes an ideal beginner sander or for those simply using it for light use for shaping, sanding and profiling. There is a selection of hook and loop abrasive belts and discs available for various applications.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
Please note, if you require an EU plug, please ensure you purchase 113504
Belt Speed 550 m/min
Dust Extraction Outlet 58 mm I.D. / 63 mm O.D.
Overall L x W x H 470 x 370 x 295 mm
Power 370 W
Rating Occasional Use
Abrasive Belt Size 100 mm x 915 mm
Plug Fitted UK 3 pin plug
Web Attribute Set Belt & Disc Sanding Machines
EAN Barcode 5052511142125
Accessories
  • Axminster Abrasive Belts 100 x 915mm (Pkt 5) - Mixed
  • Axminster Quick Release 63mm Hose Fixing Clip (Pkt 2)
  • Perform PD50E 50L Wood Dust Collector 230V
  • Axminster EU Power Cable - C19 - 2m
  • Axminster VC Abrasive Disc - 150mm
