The Perform PD610BB Belt Bobbin Sander is a versatile sander designed for accurate shaping and finishing of both curved and straight wooden workpieces. Easily switch between a 100mm x 610mm belt and five bobbin sizes (13, 19, 26, 38, and 51 mm) for versatile sanding in a compact, all-in-one design.
Ideal for internal and external curves, the PD610BB features an oscillating action that helps deliver a smooth finish. The 115mm high bobbin and interchangeable belt allow for efficient material removal in tight or broad areas.
The front section of the large 405mm x 400mm cast table tilts, with preset stops at 15°, 22.5°, 30°, and 45°, providing reliable support for angled sanding. The integrated storage keeps the belt attachment neatly stored when not in use, keeping your workspace tidy.
Powered by a 450W motor, the PD610BB offers variable spindle speeds between 1,000–1,800 rpm and a 16 mm stroke length, ensuring effective sanding performance on a variety of materials. A 50mm dust extraction outlet helps maintain a cleaner working environment.
The PD610BB Bobbin Belt Sander makes a great beginner or light use sander, eliminating the need for two machines due to the two-in-one feature.
Please note these machines are designed and manufactured for sanding wood and similar materials and should not be used to abrade or grind metal.
