The SENCO AC4504 is a low noise, oilless compressor. The compact, neat design makes it highly portable. This high-spec compressor is suitable for trade, professional or home workshop use. Reliable and robust, the SENCO AC4504 is exceptionally quiet compared to standard compressors. With a noise level of only 58 dB(A) (the average vacuum cleaner is 70 to 75 dB(A)) it causes minimal disturbance to your working environment. SENCO has built a lot into a small space, a high quality motor, twin cylinder compressing unit and a 4-litre tank. Oil free technology provides clean oil-less air. Oilless compressors are low maintenance and produce less heat compared to other compressors. Reduced condensation decreases the chance of problems with air tools. In addition, less condensation means less frequent draining of the tank.
The SENCO AC4504 features a convenient carrying handle for portability. Four suction style feet offer excellent stability.
It comes fitted with female Euro air coupling.
Overall L x W x H 355 mm x 258 mm x 290 mm
Power 240 W
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 69 dB(A) [1.5 dB]
Cable Length 1.8 m
Sound Pressure Level LpA [Uncertainty K] 58 dB(A) [1.5 dB]
Plug Fitted UK 3 pin plug
Web Attribute Set Air Compressors
EAN Barcode 7331274016385
