If you are looking for a professional headless pinner, then the SENCO FinishPRO 10 should be top of your list. This neat air nailer is lightweight, reliable and user friendly. It does the job it’s designed to do perfectly.
The FinishPRO 10 pinner is designed for finishing and fixing trim such as mouldings, glazing beads, furniture decoration and the like. It fires headless pins, enabling you to fix even the finest decorative trim securely. The FinishPRO 10 fires 23-gauge (0.6mm) headless pins ranging in length from 12mm to 25mm. The adjustable depth of drive allows you to drive the pins precisely into soft or hardwoods; leaving a virtually invisible hole that doesn’t require filling or any further attention.
The FinishPRO 10 features a non-marring bumper pad, reload indicator, hardened alloy steel driver for durability and a soft grip for comfort and control.
Supplied with a male Euro connector, carry/storage case and a one year warranty.
Inlet 1/4 NPT
Overall L x W x H 225 mm x 41 mm x 171 mm
Rating Trade/Professional
Web Attribute Set Air Nailers & Staplers
EAN Barcode 741474305894
