In Detail
The Shaper 6.35mm x 38mm (1/4x 1.1/2) Upcut Spiral Bit instantly clears waste out of the cut. Made from solid carbide these cutters ensure a very clean and smooth fast action, greatly reducing tearout, leaving a smooth finish, and is extremely durable. Suitable for wood, man-made timber products, acrylics and non-ferrous metals. Cutting depth up to 1.1/2 in depth.
It has a 1/4 shank with the added benefit of a longer overall length and a longer cutting length for deeper passes and improved stability in deep channels.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Overall Length: 75 mm (3)
Shank Diameter: 6,35 mm (1/4)
Cutter Diameter: 6,35 mm (1/4)
Cutter Length: 38 mm (1.1/2)
Geometry: Upcut, Spiral, 2 Flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
