This speciality solid carbide router bit is designed to make fast work of roughing cuts, removing material quickly and cleanly. This bit will change the way you work with your Shaper Origin. With a diameter of 16mm it will make short work of all your pocketing operations. The three-flute geometry reduces load on the spindle, decreases heat build-up, and keeps your cutter edges sharp and clean through hours of cutting.
Overall Length: 65 mm
Shank Diameter: 8 mm
Cutter Diameter: 16 mm
Cutter Length: 16 mm
Geometry: Clearing, Spiral, 3 Flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
