The STANLEY 2-in-1 Workbench & Vice features a robust and durable bamboo worktop with a removable middle plate. Removing the middle plate enables vertical clamping. It has two working heights (595/775mm) for flexible use depending on the application, eg. as a workbench, vice or sawhorse. The workbench is fitted with anti-slip feet for increased safety and it can be easily folded down for space-saving storage and easy transportation. Specification: Max. Load: 250kg Work Table Dimensions: 610 x 370mm Working Height: 595/775mm Clamping Range Between: Plates 0-26cm, Jaws 0-42cm Total Weight: 10.5kg
Manufacturer Part Number 1-83-400
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 3253561834004
