Unleash your creativity with this Axminster Pyrography Station. This powerful woodburner produces 30W and an output voltage variable from 0.5V to 1.6V. Perfect for the beginner or as a second burner for the professional it has a variable output which can be achieved by rotating the knob on the front panel. This gives more control over the tip temperature, allowing a greater variety of materials to be worked. Supplied with a variety of tips, standard, pointed and flat tips, you can achieve an array of designs.
Star Tec
Star Tec Variable Output Woodburning Station - 230V
| Web Attribute Set | Pyrography |
| EAN Barcode | 4016049171003 |
