The Starrett S3120NG Floor Standing Bandsaw delivers accurate metal cutting performance for demanding environments. Designed to handle solid materials, tubes and profiles with ease, it combines robust construction, efficient operation and versatile cutting capabilities to meet the demands of busy workshops.
Built for reliable day to day use, the S3120NG Floor Standing Bandsaw offers a cutting capacity of up to 170mm for tubes and profiles, and 75mm for solid materials. For angled cutting, the adjustable bow allows precise mitre cuts up to 60°.
Powered by a 750W (1HP) motor, the saw features variable cutting speed between 32 and 64m/min, allowing you choose the speed depending on the material. The bow can be operated in either manual or gravitational feed modes, with a hydraulic cylinder providing controlled, consistent bow advance for smoother cutting and improved blade life.
A 19mm bandsaw blade offers excellent durability and cutting performance across a wide range of metalworking applications. The blade tensioning system simplifies setup and maintenance, while the dual-point cutting fluid circulation system helps keep the blade cool, improving cut quality and extending blade life. The quick-grip vice secures workpieces firmly for accurate results and the ergonomic operating lever enhances user comfort during extended periods of use. Additional features include a 500mm measuring rod for repeatable cuts, an emergency stop button for enhanced safety and full CE compliance.
The Starrett S3120NG Floor Standing Bandsaw makes a versatile metal cutting bandsaw ideal for both heavy duty and smaller workshops.
Overall L x W x H 1,520 x 1,100 x 1,810 mm
Power 750 W
Rating Frequent Use
Plug Fitted UK 3 pin plug
Web Attribute Set Metal Cutting Bandsaws
  • UK Mainland - £70
