The UJK HSS Countersink is an essential tool for anyone looking to enhance their woodworking projects. Made in Austria and manufactured from high-speed steel (HSS), this countersink is designed for precision and durability, ensuring long-lasting performance and resistance to wear.
The UJK HSS Countersink ensures clean, burr-free holes whether you're working with hardwood, softwood, non ferrous metals or plastics.
The UJK HSS Countersink is made in Austria from high-speed steel (HSS). The chatter-free design, provides a smooth, clean finish without any burrs. It can be used with drill presses, CNC machines, and handheld drills, making it a truly versatile addition to any workshop. Recommended running speed 600 - 2500rpm.
Countersink Size 16 mm
Intended Use Designed to create a conical hole that accommodates the head of a screw.
EAN Barcode 5052511137466
